Naviate Daylight September release news 2024
6 min. readlast update: 12.01.2025
Release includes 2025.0
Use my.symetri.com to download your Naviate applications. We have added a new tab to My Symetri to allow you to download software from Symetri.
Note! Depending on the settings for your account you may see more tabs or not see the Application tab at all.
Note! Only new versions will be available on the Applications page on my.symetri.com. Older versions can be downloaded from naviate.com/downloads/ as before.
Check for updates
  • until next startup – Remind me next time Revit/Naviate is started (default).
  • 1 day – Remind me when starting Revit/Naviate next day.
  • 1 week - Remind me when starting Revit/Naviate next week.
  • 1 month - Remind me when starting Revit/Naviate next month.
  • until next version – Don’t remind me until a newer version has been released.
Updated Symetri login
Updated Symetri licensing
Lux and FTC Unit Support
Calculation of Daylight factor now includes Lux and Foot Candle. Run the daylight factor calculation as usual and they will be included in the calculation window.
