Naviate Electrical May release news 2026
2 min. readlast update: 06.11.2026
*Note: This page is under development and subject to change. Naviate Electrical development is still in progress and details may be updated before release.
This release news includes a release for the following Naviate Electrical versions, now available for download at My Symetri -> Applications:
  • 2023.1.19
  • 2024.10.1
Improved compatibility with other Revit add-ins
Background updates have been made to reduce the risk of conflicts when running Naviate applications alongside other Revit plugins.
Previously, a shared software component (System.Text.Json) could clash with the same component used by other add-ins, in some cases causing Naviate products or other plugins to stop working. We have removed this dependency to lower the risk of such conflicts occurring.
Please note: While this update significantly reduces the likelihood of compatibility issues, it does not eliminate all possible conflicts with third-party plugins. If you experience any issues, please contact our support team.
IFC Space Copy - Improvements
  • Added compatibility with IFC4.
Copy Circuits
  • Improved the workflow for copying Panelboards by adding a third click to identify the Host of the copied elements (i.e. Linked Walls). This modification is due to a Revit API change.
  • For Panelboards and Electrical Fixtures, the value of Parameter 'Schedule Level' is populated to which Level the element is located.
  • Corrected previous behaviors of the newly circuited elements being rotated incorrectly or copied to an incorrect elevation.
  • Handled a previously unhandled exception in the scenario that a Panelboard Family Instance does not have enough slots and Feed Through Lugs is unchecked or already in use.
  • Command will now skip copying Elements that contain multiple Electrical Connectors, with a warning notification message indicating results.
Export to XML for Nettdok / Import XML from Nettdok
  • Updated UI headers to include Naviate Help/Support buttons.
  • Quick Create 1-Line / 1-Line Schedule Sync
    • Resolved a syncing issue error when a Drafting View contains Spares/Spaces.
  • Export to XML to Nettdok
    • Resolved a reporting error if properties in MEP Settings > Electrical Discipline Units is rounded to 0 decimal places.
  • Import XML from Nettdok
    • Resolved a Revit crash when importing XMLs with unexpected formatting.
  • Update Text / Update All Text
    • Resolved unhandled errors in non-Plan Views, or when Views are deleted in the Project Browser.
