*last updated August 12, 2026
Naviate MEP + Fabrication: Known Issues
| Product | Version | Command | Description | |
| 1 | [N] Fabrication | 2021-2026 | Fabrication Bloom Settings | Worksets set in Fabrication Bloom settings are not applied when Blooming from an ITM to an ITM. |
| 2 | [N] Fabrication | 2021-2026 | Hanger Host Elevation Update | Command may have unexpected results for Cable Trays. |
| 3 | ||||
| 4 | [N] Fabrication & MEP | 2021-2026 | Set Slope | Values using commas as a decimal may produce unexpected results. |
| 5 | ||||
| 6 | [N] MEP | 2021-2026 | Copy Monitor Plus | Newly copied CM+ RFAs could have an Elevation value referencing Project Base Point, rather than its host’s Level. CM+ Color Toggle may display incorrect colors immediately after Copy. |
| 7 | ||||
| 8 | [N] MEP | 2021-2026 | Create Circuits | Command may unexpectedly cancel if ‘Voltage’ or ‘Number of Poles’ parameters are instance parameters |
| 9 | ||||
| 10 | [N] MEP | 2021-2026 | Split and Split with Gap | When command is executed near a Fitting instance, the command will error. If Continuous Modeling is enabled, the command will undo any executions in the transaction. |
| 11 | [N] Fabrication | 2021-2026 |
Elbow Commands Modified Aug 3, 2026 |
Slope may not be applied to the resulting Ductwork if executed from a Sloped Fabrication Duct. When executed on Sloped Fabrication Duct, the Fab Elbow Commands may produce non-orthogonal Straights. |
| 12 | [N] MEP | 2021-2026 | Elbow Commands |
Elbow commands currently do not support running for multiple non-vertical elbows. A rotated 'Bloom' Duct could be modeled on Rectangular Duct Fittings if chained from another Naviate Modeling command. |
| 13 | [N] MEP | 2021-2027 | Spool Manager/Advanced Renumber | Renumbering a Spool from a 2-digit to 3-digit number, or 3-digit to 4-digit number, may not execute AutoPadding. |
| 14 | [N] Fabrication & MEP | 2021-2026 | Advanced Renumber |
| 15 | [N] MEP | 2021-2026 | Reroute Around | Command may have unexpected results when executed on multiple straights. |
| 16 | [N] Fabrication | 2021-2026 | Fab Kick 90 | |
| 17 | [N] MEP | 2021-2026 | AutoRouting | For sloped MEP straights, if AutoRouting is executed with the 90-degree option, the resulting vertical straight will not be truly vertical. However, the resulting Elbow will be 90.00 degrees. This is a Revit API limitation. |
| 18 | [N] Fabrication | 2021-2027 |
Spool Manager Added July 30, 2026 |
After Create and Place Views, checked Spools will visually display a different Profile, although the correct Profile Options settings are applied to the Views and Sheet. This will revert to the correct Profile after close and reopen of Spool Manager. Spool Schedules may not place at the true corner or edge of the Titleblock when Match Template is used. |
| 19 | [N] MEP | 2027 |
Vertical CT Routing Added Aug 12, 2026 |
When executing the command, cursor will show a no-place symbol, not allowing placement of any Cable Tray. Switching from one View back to the original View is a workaround. |
| 20 | [N] Fabrication | 2021-2027 |
Hangers/Points Added July 30, 2026 |
When a Fabrication Hanger has an associated Naviate_Point.rfa placed at the end of the Rod, if the Hanger is deleted, the Naviate_Point.rfa will not be deleted. |
