Naviate Road June release news 2024
2 min. readlast update: 01.12.2026
Changes are available in Naviate for Civil 3D 2024.3 release.
Subassembly
There is a new subassembly DaylightRockCutB_NV that has a horizontal rock shelf instead of “follow surface”. Either use NvSubassembly to insert it or to change an inserted DaylightRockCut_NV subassembly use Properties window and change .Net Class Name to DaylightRockCutB_NV.
Copy Corridor
Copy Corridor now copies Overrides and Transitions.
Extrude
Extrude can now support templates. When a template is saved, you get the option to save a description file. It can also create multiple Extrudes in the same command, and a Copy option is available in Edit. Also has a Preview. The command can also apply IFCExport to prepare for IFC Export.
3D Measure
3D Measure can now support templates. When a template is saved, you get the option to save a description file. The command has been updated with options to place blocks at Start/End of the line. It can also insert other blocks at the start/end to support for instance railings that have a start-segment and end-segment that is different from the main railing. Also has a Preview. The command can also apply IFCExport to prepare for IFC Export. The command now supports MVBlocks as well as Note-labels.
  • Corridor-Solids (NvCorShapeToSolid+NvCorLinkToShapeSolid) now uses 0.01’ in Imperial dwgs
  • Update Feature Line Label Group - now reports when alignment is missing and allows change to existing alignment
