Naviate Structure September release 2024
6 min. readlast update: 11.27.2025
Release includes 2025.0
Use my.symetri.com to download your Naviate applications. We have added a new tab to My Symetri to allow you to download software from Symetri.
Note! Depending on the settings for your account you may see more tabs or not see the Application tab at all.
Note! Only new versions will be available on the Applications page on my.symetri.com. Older versions can be downloaded from naviate.com/downloads/ as before.
Check for updates
  • until next startup – Remind me next time Revit/Naviate is started (default).
  • 1 day – Remind me when starting Revit/Naviate next day.
  • 1 week - Remind me when starting Revit/Naviate next week.
  • 1 month - Remind me when starting Revit/Naviate next month.
  • until next version – Don’t remind me until a newer version has been released.
Updated Symetri login
If you have rights to manage licenses on My Symetri there is now an option to create a license file including Single user licenses that you can copy to machine not connected to internet.
A zip-file is generated and downloaded by the browser. Extract the included license files and copy them to the %appdata%\Symetri\Licensing folder on the machine you want to use off-line when you are logged in as the user specified when creating the license file.
Updated Symetri licensing
New Rebar Numbering
Now you can number the straight bars using their cut length.
In New Rebar Numbering Configuration, you can choose to use Numbering method, Number Strength bars by Cut Length:
You can activate the "Number by Cut Length" feature for each partition individually. When numbering is applied, straight rebars will be assigned numbers based on their cut length.
Tip! For additional information about New Rebar Numbering feature, see: Configure Rebar Numbering
  • New Rebar Numbering: Fixed issues when grouping rebars in projects using imperial units.
